Hydraulic Helms >
Hydraulic Helms
Hydraulic Helms
Old 01-22-2023 | 07:45 AM
Default Hydraulic Helms
What the difference between a hydraulic helm for an IO vs an OB? Found a used SeaStar SKU:HH5779-3 / UPC:HH57793. It's listed as OB some places and universal others. I want to add external steering to an IO. Any help is greatly appreciated.
Smitty275 is offline
Old 01-22-2023 | 08:32 AM
Veteran: Army
Typically an I/O is going to have a power steering pump mounted to the engine whereas an OB will not. The OB helm acts as the pump whereas the I/O does not.
DrFeelgood is offline
Old 01-22-2023 | 08:36 AM
This may help.
JaniH is offline
Old 01-22-2023 | 09:17 AM
you need to match the volume/flow of the helm with the cylinders and there are a lot of variables... you could get it right or end up with too many turns lock to lock and insensitive vague steering or not enough and twitchy steering.
phragle is offline
Old 01-22-2023 | 10:41 AM
That's what I was thinking. I can get everything needed thru our shop customers except a helm. I'll have to check volume of the cylinders and go from there.
Thanks Guys
Old 01-22-2023 | 01:30 PM
I have a hydraulic helm on my 30' Cobalt with power steering pump. My Arnesons had no provisions for cable. For high speed testing I had the rams in parallel, slowing the steering remarkably. I never did bother going back to series plumbing because the extra few turns didn't really bother me. Never missed the steering on the I/O TR's.
HEMTT is offline
