Bravo Vertical Shaft Splines >
Old 01-25-2023 | 06:24 PM
Default Bravo Vertical Shaft Splines
Slight twist in vertical shaft splines. Noticed it when ready to mate back to upper after skeg repair and repaint. Run it or repair?
Running 502mpi's in a 380 PowerQuest
Cory H is offline
Old 01-26-2023 | 02:37 PM
REPLACE. Its looks like more than twist with some visible cracks.
I've put one back on that some twist, but not as bad as yours.
Griff is offline
Old 01-26-2023 | 02:44 PM
Cory,
I don't really know a DAMNED thing about the intricacies of outdrives, but I agree with Griff. You're starting to see some shear in those splines, not just twist. Just from a failure analysis standpoint, it's time for it to go.
Thanks. Brad.
(937)545-8991
Brad Christy is offline
Old 01-26-2023 | 03:45 PM
I guess it would depend on if your seatow membership is paid up, you will need them with that shaft
compedgemarine is offline
Old 01-26-2023 | 06:21 PM
Is that just a swap out part, or reset up shims? How many hours labor should I expect?
Cory H is offline
Old 01-27-2023 | 07:20 AM
The entire house will be disassembled to get to the bolt that holds the gear on the shaft
https://www.mercruiserparts.com/bam/...30967/1943/220
Need to check shims and or change, I would guess a couple hours for someone who does it a lot
Edit: might find other things that need replacing once inside and things a measured
AllDodge is offline
Old 02-14-2023 | 09:40 AM
I can guarantee that the gears in the upper will fail soon have them checked. Ask me how I know.
ThisIsLivin is offline
Old 02-23-2023 | 02:13 PM
I had a couple that looked just like this seems to be a weak spot. need a fast arm
clavoie629 is offline
Old 02-27-2023 | 11:48 AM
Well, this would have happened three years ago and close to 200hrs of use. Would have never known, had I not pulled lower to have a skeg welded. Now hopefully, port drive is ok. It was fresh with new gears and bearings 3yrs ago.
Cory H is offline
