Kiekhaefer seal
I have Kiekhaefer pumps for my tabs with the older style canister that has the bolt and o-ring on the underside to seal it. I ran across the replacement bolt/seal a few months back, but can't find them now. I've spent the last two hours and coming up short. Anyone have a link they can share?
Thanks!
Thanks!
does it look something like this? if this is the wrong one contact Mark at BAM as I am sure he can get you the right ones
https://www.mercruiserparts.com/bam/...32085/8504/430
It seems this style would be less likely to leak, not having to rely 100% on that bottom seal.
Thanks again for the input.
I have replace plenty of the plastic ones, never the steel canister ones. once you put a new seal on the bottom and the o-ring it is likely good for another 20 years. the plastic ones warp over time and develop cracks around the thru bolt that comes in from the bottom to hold it on.
I just cancelled the order and will try to get those seals on order tomorrow.
Probably saved me $80 bucks and the headache of messing with them again in 4-5 years. Appreciate it!
