need info on bb-cylinder head part no:.....
330864.....68-84...oval...OPEN...396, 402, 366T,
427T, 454 Truck
330865.....68-84...oval...OPEN...396, 402, 366T,
427T, 454 Truck
330866.....68-78...oval...OPEN...366T, 427T
330867.....68-73...oval...OPEN...427T
336765.....68-78...oval...OPEN...427T
336768.....73-76...oval...OPEN...427T
336781.....73-85...oval...OPEN...454, 118cc chamber, 256/114cc ports
343771.....68-86...oval...OPEN...366T, 427T, 454
343772.....68-86...oval...OPEN...366T, 427T, 454
343783.....70-76...oval...OPEN...454 Truck
346236.....75-87...oval...OPEN...454, 120cc chamber, 225/116cc ports
352625.....70-76...oval...OPEN...454 Truck
353049.....73-84...oval...OPEN...454, 122cc chamber, 255/119cc ports
366765.....74-78...oval...OPEN...427T
473328.....68-69...oval...OPEN...366T
3856206....65-66...oval..CLOSED..396, 97cc chamber
3856208....65......rect..CLOSED..396/425hp, 109cc chamber
396/375hp "Z-16" Chevelle
3856213....66-82...oval..CLOSED..366T, 427T
3856260....68......oval..CLOSED..396 Truck
3872702....65-66...oval..CLOSED..396, 427, 98cc chamber
3873858....65-67...rect..CLOSED..396, 427, 109cc chamber
3876875....77-85...oval...OPEN...427T
3904390....67......oval..CLOSED..396, 427, 98cc chamber
3904391....67......rect..CLOSED..396, 427, 107cc chamber
3904392....67......rect..CLOSED..427, Aluminum, L88, L89, 107cc chamber
3904393....68-76...oval...OPEN...366T
3908952....67......oval...OPEN...427, "M.Truck", Marine
3909802....67......oval..CLOSED..396, 427, 101cc chamber
3917215....67-68...oval..CLOSED..396, 427, 101cc chamber
3917219....68-85...oval...OPEN...366T, 427T
3919840....67-69...rect..CLOSED..396, 427, 107cc chamber
3919842....68-69...rect..CLOSED..396, 427, Aluminum L88, L89, 107cc chamber
3931063....68-69...oval..CLOSED..396, 402, 427, 101cc chamber
3933148....69-84...oval...OPEN...'69 396/265hp, 366T, 427T, 112cc chamber
3933149....68-76...oval...OPEN...427T, 122cc chamber
3935401....68-76...oval...OPEN...427T
3946074....69&71...rect...OPEN...'69 427 L88, ZL1, Aluminum, 118cc chamber
'71 454 LS6, "round exhaust port"
3964290....69-70...oval..CLOSED..396, 402, 427, 454, 101cc chamber
Large or small hex spark
plugs used
3964291....69-70...rect..CLOSED..396, 402, 427, 454, 109cc chamber
plugs used
3965198....68-69...oval..CLOSED..396 Truck
3975950....68-70...oval...OPEN...396, 402 Truck, 366T, 427T
3986133....68-85...oval...OPEN...366T, 427T, 454 Truck
3986135....69-73...oval...OPEN...366T, 427T
3986136....68-84...oval...OPEN...366T, 427T, 454 Truck
3993820....71......oval...OPEN...402, 113cc chamber, 255/114 ports
3993820....71-84...oval...OPEN...454 Passenger and Trucks, 113cc chamber, 255/114 ports
3994026....71......rect...OPEN...454 LS6, 118cc chamber
3999241....72......oval...OPEN...402, 454, 113cc chamber
6272292....70-78...oval...OPEN...402, 454
6272990....70-up...rect...OPEN...454 service replacement, used on some MKIV crate engines, 118cc chamber
10045427...........rect..........Pontiac/Chevy Aluminum, 91cc chamber
Large Port, race
10049875...........rect..........Pontiac/Chevy Aluminum
Small port, race
10051128...........rect..........Bowtie, Aluminum 72cc chambers
Symmetrical ports
10051129...........rect..........Bowtie, Aluminum "raw"
casting, Symmetrical ports
10052902...........oval...OPEN...MkIV, 427T
10101140...91-up...oval..CLOSED..Gen.V 366T, 427T
10114156...91-up...oval...OPEN...Gen.V & VI 454, 118cc chamber
10141279...96-up...oval..CLOSED.."Vortec 7400", 100cc chambers
10487052...77-90...oval...OPEN...366T
12363391...96-up...oval...OPEN...Bowtie, Aluminum, Signature
Series, fits MKIV, Gen.V, Gen.VI, 110cc chamber
12363401...96-up...rect...OPEN...Bowtie, Aluminum, Signature
Series, fits MKIV, Gen.V, Gen.VI, 118cc chamber
12560241...98-up...oval..CLOSED.."Vortec 7400", 100cc chambers
14011077...69-up...rect...OPEN...Aluminum, fits MKIV, "C-port"
118cc chamber, also sold as a "solid" head
14044861...84-96...rect..........Bowtie, Aluminum, MkIV,
"raised runners", 1st design, 105cc chamber
14044861...96-up...rect..........Bowtie, Aluminum, Signature
"raised runners", 2nd design, 115cc chamber
"raw" casting of "861" MKIV
1st design
14081045...78-87...oval...OPEN...454
14081052...85-87...oval...OPEN...366T, 427T, 454 Truck, Marked "HiPerf"
14092359...86-90...oval...OPEN...366T, 427T, Marked "HiPerf"
14092360...86-88...oval...OPEN...454 Truck
14096188...70-71...rect...OPEN...454 service replacement, also used on later Mark IV LS-6, LS-7 and 454 HO crate motors, 116cc chamber
14097088...91-up...rect...OPEN...Gen.V 454/502 HO, 118cc chamber
24502585...97......rect..........Olds/Chevy, DRCE 2,
Pro Stock aluminum, for blocks w/4.900" bore centers
427T, 454 Truck
427T, 454 Truck
plugs used
plugs used
Large Port, race
Small port, race
Symmetrical ports
1st design
ragtop;thnx but i also have lots of lists like you but the number i am looking is not listed in these lists.thnx again
427T, 454 Truck
427T, 454 Truck
386781.....73-79...oval...OPEN...454
3904392....67......rect..CLOSED..427 Aluminum, L88, L89
plugs used
plugs used
3993820....71-84...oval...OPEN...402
3993820....71-84...oval...OPEN...454 Truck
Large Port, race
Small port, race
10051128...........rect..........Bowtie, Aluminum 68cc chambers
Symmetrical ports
10114156...94-up...oval...OPEN...Gen.V & VI 454
12363425...96-up...rect..........Bowtie, Aluminum, Signature
"raised runners", 2nd design "861"
12363861...84-96...rect..........Bowtie, Aluminum, MkIV,
12363861...96-up...rect..........Bowtie, Aluminum, Signature
12363862...84-96...rect..........Bowtie, Aluminum, MkIV
1st design
T = Tall deck
427T, 454 Truck
427T, 454 Truck
plugs used
plugs used
Large Port, race
Small port, race
Symmetrical ports
1st design
T = Tall deck
Tim I would double check the number clossely I think it is the 346236 because it would be easy for the 3 to apear like an 8 and as far as I now GM nver used the last thre digits twice 236. Most people only refer to them when talking about GM parts.
i think you are right;its 02:15 here.will check them tomorow.
thnx 2 much
ragtop can you estimate/or do you know approximately: how much does this heads flow at 650 lift? any idea?
thnx 2 much
