Valves
Old 02-28-2023 | 08:05 PM
Default Valves
Getting ready to put a set of aluminum heads together. I've always believed in using a Heavy Duty intake and Severe Duty exhaust for marine use. But is it really necessary in a naturally aspirated application? Would a standard race valve be sufficient. End goal is 600hp BBC.
Opinions please.
Smitty275 is offline
Old 03-01-2023 | 12:26 AM
IMO, YES.
Inconel exhaust valves, when do you need them?
Griff is offline
Old 03-02-2023 | 08:44 PM
DRAG's Avatar
Good valves aren’t that expensive and cheap valves aren’t that cheap. Go for some good stuff and don’t skip the inconel exhaust.
DRAG is offline
Old 03-03-2023 | 03:31 AM
Veteran: Army
Not the place to save a few bucks in a marine engine build.
DrFeelgood is offline
Old 03-03-2023 | 04:49 PM
I'm right there with all of you. Just wondering if technology had gotten good enough of the race series of valves. Did get a rare chance to talk to an old acquaintance that builds offshore power for a living in Virginia. He said they use Manley Severe Duty in everything naturally aspirated. If it's got a blower they go to inconel for the exhaust.
Old 03-04-2023 | 11:56 AM
articfriends's Avatar
Its always been a question. I have personally never had a valve failure BUT I use better inconel exh valves in everything. Im currently building a pair of 502 mpis with factory heads, same question, the factory uses Eaton Inconel exhaust valves BUT they are 2 piece , a hp500 and 500 efi with same heads uses manley inconel exh valves, more spring pressure, more rpms, more lift. Could I have reused the eatons, probably BUT I never have reused them with more spring, lift, rpms as a failure will make me go far backwards on a build when custpomers mad AF at me ! so as much as Id like to, would cost $$$ big if a head comes off. Smitty
articfriends is offline
