Best Way to Bleed Surge Brakes
Old 03-06-2023 | 10:42 AM
Default Best Way to Bleed Surge Brakes
I had purchased a pressurized brake bleed kit from Speedi-Bleed to do my vehicles. I had just replaced the entire brake system on my 03 Suburban and wasn't going to speed 3 days yelling up and down to my wife. Needless to say this thing is awesome. My trailer is 12 years old and other than repack bearings I hadn't touched the brakes. So I made an adapter for the master cylinder and used the pressurized bleeding system to get the job done in under an hour. Here is a picture of my adapter.
ThisIsLivin is offline
Old 03-06-2023 | 10:56 AM
Wally's Avatar
Were doomed!
A vacuum system would work as well. I spent a few hours trynig to bleed the brakes on my 2010 avalanche. after replacing both rear calipers. Just would never bleed out right and pedal was always spongy. So i hooked a vac up to the master cyl and BAM back to normal
-Wally
Wally is offline
Old 03-06-2023 | 02:33 PM
SB
Good job.
I have a pressure system too. Definitely the way to go, even over vac systems, for most brakes . clutches, and etc.
I make the adapters the same you did for things I don't have, or they don't sell, an adapter for. Buy another cap and put a fitting in it.
SB is offline
Old 03-10-2023 | 06:34 PM
Air press bleeding works well, just don't let the master cyl run out of fluid.
zz28zz is offline
Old 03-11-2023 | 06:05 AM
one assumes you only use a few psi of air pressure?
Baja 252 Islander
bajaman is offline
Old 03-13-2023 | 01:49 PM
I use 30 psi to the regulator on the bleeder and 15psi on the master cylinder. I have tried suction style bleeders and they are garbage compared to the Speedi-Bleed. The problem with the suction style is they pull air around the threads of the bleeder. Pressure bleeding is sealed and no air bubbles. I use the suction bleeder to suck the oil out of my lawnmower now.
Old 03-14-2023 | 06:19 PM
Boy do I feel stupid for all the yrs I used a trailer ball, bolted to a stick, locked in the coupler while I pushed!
Twin O/B Sonic is offline
Old 03-20-2023 | 05:22 PM
Originally Posted by SB
Good job.
SB,
I think I see another project in my future.....
Thanks. Brad.
(937)545-8991
Brad Christy is offline
Old 03-20-2023 | 07:33 PM
SB
Especially if you didn’t make your wife do it.
SB is offline
