25% slip
27’ Fountain single step
18.5” X Dimension
Bravo upper standard height IMCO lower
1.50 ratio
280 K planes
28p B1 - new out of the box
540BB, Dart heads/intake, hyd roller w a 1050 ProSystems. Made 640/630tq with standard headers so not sure what it’s actually turning at the shaft.
Had a 26p B1 on it and the boat will run 72-73 @5800. Picked up a new 28p B1 and it runs 72-73 @5400. Same mph and roughly same slip %. I only got to run it a couple times with the new prop before the season ended.
Plan to really do some testing this spring to feel the boat with different trim / tab adjustments and capture slip numbers. I’d really like to test mid range cruise. I know it should be higher, but may help put together what the hull likes. Typically at WOT I’ve got the tabs all the way up and drive around 4-4.5. Maybe I’ll get it dialed in with seat time, but wanted to open up props for conversation.
I contacted Brett last fall and I couldn’t find the email
so maybe he called me back, either way he seemed to lean towards me needing to address the slip before fixing it with a prop. Maybe he’s on to something because the new B1 made no difference other than a drop in RPM - which was a positive.
I see a lot of Fountains running Hydromotive and one guy said a Maximus really helped, dropping slip by about 10%.
The boat runs fine, but I’d really like a little more top end out of it and feel it’s capable.
18.5” X Dimension
1.50 ratio
280 K planes
Thought about a GoPro in the side mount may help. I do know once I trim it up it starts to chine around 70, so I have a feeling it’s on the pad.
Not a Fountain owner but my Velocitys always ran faster with Hydromotive. Reggie used to ship his single engine boats with a Hydromotive prop until Mercruiser put the screws to him and made him use Bravos.
Padraig
Padraig
below 80 the imco nose cone hurts more than it helps. I tried one on a 27 fountain years ago, went to a -2 and it was 1-2 mph slower than the stock lower.
Every other boat I’ve ran an imco on that was slower than 80 or didn’t need the shorter lower ran slower.
Thanks. I haven’t looked into it much but could I put on one of those aftermarket nose cones possibly?
Mainly from ignorance. Did some reading and see your point. I am curious though your thoughts on switching on the IMCO for a B1 or XR. Thank you
