Water pressure gage install on 500EFI's
Hi Guys. Did a search but couldn't quite find what I was looking for. As title says I'm adding water pressure gages to my 500EFI's and wondering where is the best location to tap into the cooling system.
Also what would be considered "normal" pressure at say cruising at 3000 rpm?
Thanks!
Thanks!
Many tap replace a drain plug with a threaded barb
The pressure depends on a few things: are you using stock bravo pickups? Transom mounted? Relief valve?
15-25 PSI is usually a safe bet for WOT and a good pressure to aim for
I connected to Tee fitting on port side of block with mechanical gauge, 1/8 inch tubing
Cold idle close to 5 to 6, once thermostat opened would see 2 to 3
Cruise (36 to 3800 rpm) around 25 with new impeller, WOT a bit more
509 MPI, bravo pickup and Merc pump
Thanks all. Gages are still being shipped and include the polyethylene tube. Didn't realize the pressure was as high as mentioned. I assume the hose uses a clamp to the barbed fitting? Definitely wouldn't want that line to blow off. Was thinking those shark jaw type fittings used with polyethylene plumbing may be the ticket unless screw style clamps are sufficient.
On my old boat it had the reading taken from the block drain, it would constantly clog.
On my 502mpis, the fittings are in the T stat Housing. Never had a clog in 16 years. The TStat housing or intake manifold are better locations IMO.
You should see 1-2 psi at idle, 10-20psi at cruise rpms and 20-30psi at WOT
