Aluminum cylinder head question AFR enforcer 335
https://www.summitracing.com/parts/afr-3001
So my machine shop called stating my stock iron heads off my 502 which is in the process of a fresh rebuild are not in the best of shape but could be saved. I said what if we look for a set of aluminum heads without smoking the bank since im already way over budget and we found these AFR enforcer 335cc heads. I called AFR and they started off stating they are a import casting but if im not adding boost and looking to be in the range of 600hp their perfect.
I just ordered them so I can still cancel it through Summit but ARE THEY TOTAL JUNK? I mean $863 ea for an assembled head compared to their Magnum line 325 hed which is $1,705 ea scares me.
Again this boat is not raced or even run hard, it is a simple pump gas lake boat but I also do not want to do this again and im not running any crazy cam in it.
Am i calling back and switching my order to these:
https://www.summitracing.com/parts/afr-2101
Thoughts an opinions please.
If they are preassembled from any manufacturer you are going to want to have them went through by your builder. I say this not from experience but due to the fact of reading too many build threads on here to count about them not being set up anywhere near correctly out of the box. FYI.
To your question on the port height....my heads have raised ports and I had to raise my tips the same height as the port raise...I believe mine were 1/2 or 3/4 inch raised I can't remember but I will say I had to do it due to my exhaust configuration. My tails curve in towards the center of the boat and I wasn't able to get them to line up with the flex in the couplings. Also when you go up they generally move the headers out as well at least mine did because the angle of the exhaust flange is not parallel to the vertical plane of the engine....hope that makes sense lol.
My opinion...not sure what lake you run on but I do know of at least 3 people personally here on lake michigan that only got 3-4 years out of aluminum heads in lake michigan water only. It's not only slat water that is corrosive. If you're building this to not have to be worked on and inspected constantly I would go with a good set of iron heads....dart iron eagles or something...I went iron on mine and had them ported and they flow as good or better than AFR aluminums and I don't have to worry about corrosion. I have enginequest heads which I can't seem to find anymore but there are threads about them on here by "mild thunder" if you search enginequest heads. That's just my opinion and you can easily get to your horsepower goal with iron heads...can probably get a good set of stock merc 500 or 525 efi iron heads and get to your power goal easily and never had to worry about them.
Yeah Im not dealing with moving tips in the transom im cancelling the order 100% That alone besides the rest of your post made my decision!
