TRS Drive height?
On a 38’ Cigarette Flatdeck what is the correct height for TRS drives? How far below the hull should prop centerline be??? Everyone says raise them a couple inches, but where exactly does that end up?
On my Cafe, i measured my TRS Xdim @ 17.5". My simplistic measuring had my prop centerline at 8" below hull.
I purchased a pair of Konrad ACE drives to replace the TRS. The standard HP 540 lower is 1.7" higher than the TRS, but mine have the X-Factor's. They are another 1.7" higher than the the HP's, or 3.4" higher than TRS. Using the original drive centerline, i would be at 4.6" below the hull.
I havent had the new holes cut yet, but i am thinking about raising the Xdim another .5 - .75" so they sit 4 "- 3.75" below the hull. The ACE has an extension box so i been told to run mine higher.
In full disclosure i didnt realize what i was buying from classifieds was an ACE, & now doing a bunch more work than originally anticipated. I thought they were regular 540 TRS replacements. But after getting them, i liked the looks of it all & said F-it, i am already putting in a new transom (& subsequently stringers too) i have the opportunity to start fresh. The ACE is a Bravo replacement, so i am having to move the engines back, & then my BW's hopefully mount in the extension box as they would have with the BAM 1350's that come new.
I have a similar question. I may post in another thread but I'll toss it out here. 87 Chris craft stinger 390 X. Owner replace the original TRS drives with Konrad's and injected 540s. I'm assuming in the stock location. The boat comes out of the hole OK but appears to be cavitating until it is up on a plane. My initial thought is the drives are not far enough down in the water. Thoughts?
I am building this as a family boat. I want it pretty stock appearing, kinda like a classic car. The drive’s limit the ho so it keeps me from having a few drinks and thinking I need Big Hp/speed lol. I am only redoing transom and stringers due to the boat being rotten when I bought it. The project grew lol. I even keep the roll pleat interior (expensive) lol. I always loved the drug smuggling classic look. Plus swapping to non transmission drives would move the center of gravity on the boat. I want the best family ride I can achieve with what is there. Raising the drives just seems like a no brainer since I had to do the transom.
