Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
Racing engines...what breaks most often? >
Old 05-06-2023 | 05:39 AM
Default Racing engines...what breaks most often?
Just curious for those with racing engines or who race...is there a component of the engine that breaks more often than others? From what I have seen and read, it seems the bottom end of these engines is usually pretty robust, rarely failing? If so, then would that mean valves/springs/cams would be the leader?
Baja 252 Islander
bajaman is offline
Old 05-06-2023 | 07:11 AM
i would say its the wallet that takes the biggest hit
Old 05-06-2023 | 08:06 AM
Veteran: Army
...sometimes catastrophically.
DrFeelgood is offline
Old 06-11-2023 | 03:04 PM
nocigarette's Avatar
relationships, marriages,girlfriends etc.
Old 06-12-2023 | 07:46 AM
The parts that break are the ones which you don’t have several spares sitting around for.
sonicss42 is offline
Old 06-12-2023 | 08:21 AM
Active Streak: 30 Days
Or not available until 6 months out.
Helmwurst is offline
Old 06-12-2023 | 12:07 PM
SB
Racing breaks:
Balls
Hulls
Outdrives
Valvetrain
Pistons
Rigged components
and everything others mentioned
SB is online now
Old 06-12-2023 | 03:18 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Usually, it's the Loose Nut behind the throttles that causes the most problems.
Sydwayz is offline
Old 11-03-2023 | 05:46 AM
byrideroffshore's Avatar
You guys are too funny…but you are all correct… bajaman having raced supercat for a few years and being
directly involved in engine development, the valvetrain / camshaft are the biggest hurdles in racing that class. Things we’ve done included 55 mm roller cam bearings , truing up lifter bores. Bigger diameter lifters, various ramp designs on camshafts, using tool steel
camshafts, valvespring pressures , made own in-house rockers, used various retainers/ locks . The biggest helpful change was when we lowered the RPM to 7000 it helped stabilized it Speeds went down aiding in the safety of it. At the time I felt canopy construction was still lacking. Still loved the sound of the big block screaming at 7600 rpm kinda missed that.
byrideroffshore is offline
Old 11-03-2023 | 10:18 AM
TeamSaris's Avatar
Driver-441
Racer
when we had the spec motors in Stylin spinning 7400 valve train was the hadrest just as byrider said. Pleasure boat parts wont live in the race environment.
hope you're well btw!
TeamSaris is offline
