Scarab 33AVS Holding Tank
Hello friends!
I have a 33 AVS(in Greece) with holding tank and macerator. The Macerator stopped working last week, and in the next days my mechanics will go for checking and fixing.
Does anybody knows where the macerator and the holding tank sitting on a 33AVS?
I found some pictures from the owners manual reffering to 38AVS (and not 33AVS), showing the tank somewhere close to the storage locker inside cabin, in front of cockpit.
Any ideas?
Thank you.
* i ask, because in Europe we are not familiar with vacuum heads.
Any ideas?
Thank you.
The macerator pumps with a "y" valve were typically under the rear seat in the storage bin and the holding tank just below that, accessible by removing the diamond plate at the base of the of the engine compartment bulkhead, as I recall The vacuum pump should be under the floor/base panel of the mirrored storage compartment adjacent to the head compartment.
The problem was "cut wires", probably some rough water played its role!
But now, the head is leaking and i see the fluid on the compartment floor.
I Know that the model is Vacuflush , 106 or 1006. There is no pedal, there is a hand lift for filling water and send to tank everything.
Could someone confirm that this is 106 or 1006 ? And if there is a kit of fixing (flanges- sealing kit), do we know part numbers or a link so i could order it (probably from US). In Europe there is ..nothing.
Thank you very much!
