best aftermarket fuel cooler to replace the factory "cool fuel" >
Old 05-30-2023 | 06:44 AM
Default best aftermarket fuel cooler to replace the factory "cool fuel"
Good morning guys,
Question, I finally got my rebuilt 509 back from the machinist and prepping it to drop back in the boat. I am replacing the stock MPI fuel injection with a Holley HP system and want to upgrade the fuel system. I am running a Holley marine rated fuel pump but it will be all -AN line so I want to replace the factory cool fuel with a new aftermarket exchanger. I found the one in the link, wonder if ti is a good choice or is their a better route to go? Engine will be in the 550hp N/A range so nothing crazy.
https://azspeed.com/product/high-flow-fuel-coolers/
Joeyboost is offline
Old 05-30-2023 | 07:38 AM
why not lose the fuel cooler and just run a return line to the tank.
sutphen 30 is offline
Old 05-30-2023 | 07:49 AM
I went with a new higher flow external fuel pump and an external fuel pressure regulator. I heard a lot of people say these cool fuel units fail as well. I have to hard proof of that but I figured I would just go all new and stay away from that unit.
Old 05-30-2023 | 11:45 AM
TomZ's Avatar
If you run the fuel back the tank, the tank acts as the cooler. It’s much simpler.
TomZ is offline
Old 05-30-2023 | 11:51 AM
I am 100% running it back to the tank, if I can eliminate the cooler all together Im good with that. I mean its a 100 gal tank I don't see that heat soaking and especially when my boat is running for maybe a 1/2hr to an hour at a clip before being anchored for hours.
Old 05-30-2023 | 02:18 PM
TomZ's Avatar
Yep, you’ll be fine that way.
TomZ is offline
Old 05-30-2023 | 09:19 PM
That`s how I did mine. Got it from Mr. Cool . It`s on the return line.
I don`t see how a gas tank would be cool in the summer heat under a floor.
Cool fuel makes more power and is better for fuel pumps, regulators, injectors etc etc.
ICDEDPPL is online now
Old 06-01-2023 | 11:04 AM
I don't see how it will heat 100gal under the floor I mean in a car there is no fuel cooler but yes it has air flow across it under the car. I would guess if your running for hours at a time at low speed where it is returning most of the fuel back to the tank it possibly could heat soak the fuel or if you get low on fuel but for the most part I dont see no cooler being an issue but I have no real world proof. I may just install one to take the "what if": out of the equation.
Old 06-02-2023 | 04:54 PM
Steve H's Avatar
artselectricinc.com
I used a cooler as shown above, and it works fine. I would have preferred a return to the fuel tank, but with three separate tanks, it just wasn't practical.
Steve
Steve H is offline
