Exhaust manifold gaskets, using actual gaskets or high temp RTV? >
Old 06-02-2023 | 09:58 AM
Default Exhaust manifold gaskets, using actual gaskets or high temp RTV?
What are you guys using on your manifolds to the head for gaskets? I know on the turbo cars I just use High temp orange RTV and it works best, never blows out. I was planning to go this route on the boat as well but I wanted to see what you guys like to go with?
Joeyboost is offline
Old 06-02-2023 | 02:45 PM
Ive used both good quality gaskets and high temp rtv over the years. Never had rtv fail
getrdunn is offline
Old 06-05-2023 | 06:54 PM
Hi temp copper, red, orange, black silicone adhesive, even clear silicone...never a leak. Haven't used a gasket on any exhaust manifold or header in at least 20yrs.
Smitty275 is offline
Old 06-06-2023 | 07:37 AM
I have Lightning headers and use both and no leaks, going on 10 years.
ThisIsLivin is offline
Old 06-06-2023 | 08:40 AM
TomZ's Avatar
Any chance that using a gasket could introduce reversion? If straight up RTV works best, that may prevent some failures some have run into. One of our guys is dealing with that right now - heads need to be redone on some really nice engines because of it.
Could be an interesting discussion!
TomZ is offline
Old 06-06-2023 | 09:09 AM
Do you guys use both gaskets and RTV at once? It looks like my previous owner did and didnt have any issues - I just picked up some exhaust wedges and another 2 gaskets, but if RTV is better I may just go that route!
CheckmateScarab is offline
Old 06-06-2023 | 10:40 AM
May have done way back in the day but when using silicone I just put a bead around the port and let it flash off for 1/2 or so before bolting up header or manifold. As mentioned in a bind I’ve used whatever kind/color is on the shelf without failure. Ideally use a couple threaded rods for lining up and drawing up evenly.
getrdunn is offline
Old 06-06-2023 | 09:51 PM
SB
Exhaust leaks can cause reversion.
SB is offline
Old 06-07-2023 | 08:33 AM
TomZ's Avatar
Yep, for sure. If a gasket can create a risk, then maybe best to leave them out.
TomZ is offline
Old 06-07-2023 | 10:12 AM
deleted
F14A water jet is offline
