Need to identify the trim pump motor >
Old 06-03-2023 | 11:10 PM
Default Need to identify the trim pump motor
Pump is good, motor smoked due to switch sticking. Want to identify the unit so i can source a replacement. 87 CC but don’t think it’s original
CaptainChazz is offline
Old 06-04-2023 | 03:03 PM
Captain, looks like an old Oildyne Pump/Metal Reservoir from Mercruiser. I've got 4 of them, I just keep rebuilding them. The Mercury ExParts viewer shows the motor replacement as part number as 17649A1. I also checked the K-tab part list and they show two different motors based on whether your wires have a spiral white tracer or straight tracer on the blue and green. The spiral tracer motor is 17649T and the straight tracer wire marking is 891736T. If you do a search for the first pump serial number, you'll get a bunch of info! Good Luck! Oh by the way, I think there a 9/16" capscrew behind the motor that holds it down in the v-block mount!
CouleeCatMan is offline
Old 06-04-2023 | 03:05 PM
great information! Thank you!!
Old 06-05-2023 | 04:31 AM
Default I might have onr
Is this the same style?
Mercruiser Oildyne trim pump
Markus is offline
Old 06-05-2023 | 06:42 AM
that looks like it!
Old 06-05-2023 | 09:14 AM
I can bring it with me to the United States in late July.
Markus is offline
Old 06-05-2023 | 12:40 PM
Below link is a replacement for the number CouleeCatMan posted.
As he said Google will open a plethora of options.
I've used alternators from the DB place before.
https://www.dbelectrical.com/product...7828-6218.html
cheech is offline
