Trim cables >
Trim cables
Trim cables
Old 06-08-2023 | 05:07 AM
bajarick's Avatar
Default Trim cables
I have a 2007 42 fountain exc. Does anyone know the numbers or length of the trim indicator cables ?
Thanks..
bajarick is offline
Old 06-08-2023 | 08:31 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If it were me, I'd reach out to these guys: https://www.facebook.com/R3CustomMarine
Source from them in exchange for providing the knowledge.
Sydwayz is offline
Old 06-08-2023 | 10:30 AM
The cable lengths are marked on the cables themselves. I'm assuming you haven't removed the old ones yet?
techman is offline
Old 06-08-2023 | 09:20 PM
bajarick's Avatar
no I haven't, I wanted to get a set first.
bajarick is offline
Old 06-09-2023 | 03:16 AM
bajarick's Avatar
I did contact them in messinger and they wrote back saying thanks for contacting us and that was it.
bajarick is offline
Old 06-09-2023 | 07:32 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Automated reply. Call them.
Sydwayz is offline
Old 06-18-2023 | 11:33 PM
On my 2008 42 Lightning the trim tab cables are Mercury Platinum. Port side is 28’ starboard is 22’. I’m trying to find the drive trim cable lengths but have not found any markings. If your going to tear it out for tabs you might has well replace the drive indicator cables.
Look through the slots to see the connection to the pointer arms. It is a threaded rod. Make sure you order the right connectors on each end as there are many to select from.
mike38scarab is offline
Old 08-21-2023 | 08:47 AM
I need help with custom cables for a 100' jet drive boat
nickevoics is offline
