2001 Merc 6.2L mx timing >
Old 06-08-2023 | 10:00 AM
Default 2001 Merc 6.2L mx timing
Do i set timing on this like my '95 502 mpi? Short pins a and b. Also, do i have the rotor pointing at #1 post at TDC, or at the 8 degrees BTDC per base timing? I have it at TDC from changing head gaskets, and it's pointing to #1 currently.
Thanks.
cloudmaster_321 is offline
Old 06-08-2023 | 12:27 PM
Title 2001 6.2
Post 1995 502
Which is it?
AllDodge is offline
Old 06-08-2023 | 01:00 PM
Knot 4 Me's Avatar
Originally Posted by AllDodge
Title 2001 6.2
Post 1995 502
Which is it?
He's asking if he would time it like you would a '95 502.
Knot 4 Me is offline
Old 06-08-2023 | 01:08 PM
correct
Old 06-08-2023 | 01:19 PM
Are the 2001 ECM's 555 or still MEFI?
cheech is offline
Old 06-08-2023 | 02:06 PM
No
And no the 6.2 is not timed like the 502. A timing light is not used nor base timing. You have a HVS distributor
Bring motor to TDC on #1 then adjust distributor as shown
AllDodge is offline
Old 06-08-2023 | 02:36 PM
How do I know if I have a HVS distributor vs not? I don't have a connector on mine like that shown........ I also have 4 distributor hold down screws, not 2 as shown.
Old 06-08-2023 | 02:48 PM
This is why it's always best to provide a serial number. Saying it's a 6.2 was telling me it's MPI and all 6.2 with MPI have HVS
And have the flat distributor cap
AllDodge is offline
Old 06-08-2023 | 05:28 PM
Not sure what to say. It's the first s/n range of the 6.2L MX motors. It is a multiport injected, if my definition of that is correct. Fuel injectors are in the intake manifold.
Old 06-09-2023 | 08:02 AM
Knot 4 Me's Avatar
Buddy with a 2002 Rinker with a 6.2L MPI does not have the flat distributer cap. I know this for a fact as I took it off when we were diagnosing an engine problem that ended up being a burnt piston.
