Another issue!  Raw water pump not lining up >
Old 06-13-2023 | 10:08 AM
Default Another issue! Raw water pump not lining up
Anyone ever have a problem with raw water pump (pulley) not lining up with crank pulley. New dart big m blk. It’s not only out over a 1/16 th it appears the lower portion also needs to be shimmed out slightly further. Being such a short belt I don’t believe there’s much room for error.
I can shim the crank pulley to solve one problem but would have to shim the lower portion of the pump bracket to get close to spot on.
Also anyone happen to have part number for that belt? My internet acting up badly. Was a mark 4 TRS originally
getrdunn is offline
Old 06-13-2023 | 04:13 PM
TomZ's Avatar
Sounds like the mounting bosses on the block are machined a little thick. No real answer outside of shimming. A picture might help.
TomZ is offline
Old 06-13-2023 | 04:48 PM
I still haven’t been able to renew membership cause I got thrown to the curb by PayPal.
getrdunn is offline
Old 06-13-2023 | 07:48 PM
You don't have to be a paying member to be able to upload pictures.
cheech is offline
Old 06-13-2023 | 08:11 PM
seafordguy's Avatar
Is this a V-belt setup? If so is the flange pressed on the right distance?
seafordguy is offline
Old 06-14-2023 | 08:02 AM
Wally's Avatar
Were doomed!
If its this stye bracket, you can loosen the screw clamping the pump snout and move it around to align up the pulley...if its the stamped style with no adjustment, then either your pulley position has changed on the pump shaft and needs to be shifted....or bracket is bent.....or you need some spacers/shims
-Wally
Wally is offline
Old 06-14-2023 | 11:30 AM
Welcome to the world of High Performance Aftermarket junk. It's all to spec until it isn't. Just shim or trim as needed. I'd trim the pump bracket to move it back before I'd shim out the crank pulley. (Unless you make a shim that matches the base of the pulley.) You may get lucky with the bracket by trimming part of it and leaving the other point alone to get it trued up
Smitty275 is offline
Old 06-14-2023 | 08:28 PM
seafordguy's Avatar
If it's the style Wally posted Trash them and use the other style. I smoked 2 sets of bearings in BRAND NEW Hardin SS pumps two years ago because when you tighten them down if you get the snout even a couple thousandths out of round you're screwed.
Honestly man, if it's a V-belt and only out a 16th or less I'd run it and lose sleep over something else....
Old 06-15-2023 | 06:04 PM
That did it. Tks. Never ran into the problem before and didn’t realized that bolt was an adjustment/set bolt. The other alignment was my bad eyes. After checking further with a straight edge and feeler gauge they were perfectly parallel. All good. Tks again
getrdunn is offline
