Crusader 454
Old 06-13-2023 | 05:06 PM
Default Crusader 454
Hello,
I have a 454 crusader, block, heads and intake manifold only. I am going to tare it down and rebuild and convert to raw water with flush kit. My question is, can I use my bell housing from a gen4 454 mercruiser with b/w transmissions? essentially converting the engine from a inboard to I/O. Wondering if I can use different exhaust manifolds and other mercruiser components. Any help would be appreciated.
Fast Too Fast is offline
Old 06-13-2023 | 05:22 PM
Originally Posted by Fast Too Fast
Hello,
Should bolt right up
tommymonza is offline
Old 06-13-2023 | 05:41 PM
F-2 Speedy's Avatar
Is the starter going to be in the same place ? meaning are they both upper rear mount now with the flywheel ring gear on the back side
F-2 Speedy is offline
Old 06-14-2023 | 06:06 PM
Yes, the starter is up top with the flywheel gear.
