AFR sensor extender >
AFR sensor extender
AFR sensor extender
Old 06-27-2023 | 11:56 PM
Default AFR sensor extender
Looking for something to help keep my o2 sensors dry. For some reason they keep getting wet and not working.
See pictures for current placement
ubet28 is offline
Old 06-28-2023 | 03:54 AM
SB
Several peeps, including Articfriends, use and promote these innovate one’s:
Lifespan on Bosch 4.9 02 Sensor
SB is offline
Old 06-28-2023 | 10:10 AM
Innovate motorsports bung extender works for me too.
LakeHuronPower is offline
Old 06-29-2023 | 07:08 AM
articfriends's Avatar
Not only does the innovate piece extend the o2, its also directional and shields the 02 from the water your most likely getting from reversion thats wrecking them, Smitty
articfriends is offline
Old 06-29-2023 | 09:39 AM
Indeed....another user of said product.
Biggest issue I had was clocking it for flow direction as I had a hard time finding thin enough washers etc.
Trash is offline
Old 06-29-2023 | 11:32 AM
I used the same extenders , I made a fixture to hold the washer and I sanded them to achieve the correct clocked position .
green lightning is offline
Old 06-29-2023 | 03:39 PM
TomZ's Avatar
I used some O2 extenders that were mentioned on here a ways back. If you do a google search for "O2 extender CEL" you'll find them. Mine had screens in them (i'm sure those help with water intrusion). My understanding is that there wasn't difference running with or without so they should give an accurate reading.
TomZ is offline
Old 06-29-2023 | 06:55 PM
Rookie's Avatar
That was me. And I ran them on Smitty's (articfriends) dyno.
Rookie is offline
Old 07-06-2023 | 09:45 AM
Just for an added data point I did direct A/B comparison both with and without the Innovate extender on the same motor, same tune, same day. No difference in AFRs.
Trash is offline
Old 07-25-2023 | 11:27 PM
Sorry been a bit but is this what I should order to replace what I have? Need to get these on the boat. Thanks
ubet28 is offline
