Ferrea valves >
Ferrea valves
Ferrea valves
Old 06-29-2023 | 08:54 PM
Default Ferrea valves
Gen V 489 big block, normally aspirated 600hp.
I am planning on using Ferrea Super Alloy P/N F2120P for my exhaust valves...OK?
What stainless steel is recommended for intake?
Thanks!
F14A water jet is offline
Old 06-30-2023 | 01:15 AM
Super Alloy definitely will be ok for exhaust valves
Griff is offline
Old 06-30-2023 | 07:39 AM
Thanks! I am also trying to get the RIGHT part # to order (both inconel exhaust and ss intake)?
Old 06-30-2023 | 08:56 AM
TomZ's Avatar
Tom,
Your machinist really needs to verify the specs for the valves. Are they stock sized or did the original builder make changes (length, stem thickness, head diameter)?
The information may be in your build sheets, but I’d verify what’s needed with your builder.
TomZ is offline
Old 06-30-2023 | 09:06 AM
If buying from mfg and you are a Vet. they give a healthy discount. FYI
GLENAMY 242SS is offline
Old 06-30-2023 | 09:13 AM
TomZ's Avatar
Paperwork shows 2.25 and 1.88 intake and exhaust valves, respectively. Probably stock-sized but have your guy verify the lengths and stems.
TomZ is offline
Old 06-30-2023 | 09:14 AM
Super Alloy is the Ferrea Inconel material. It's a great choice for a marine application.
c0ncEpT is offline
Old 06-30-2023 | 09:39 AM
TomZ's Avatar
Tom, another consideration is availability. You may find that you'll need to hunt down what you need. If I recall correctly, your machinist likes to use REV (perfectly fine). You might want to have him looking for suitable candidates.
TomZ is offline
Old 06-30-2023 | 09:54 AM
Tom,
Why are you looking for valves?
Gary
(PS I know you are a Vet I put that in for other readers info.)
Old 06-30-2023 | 10:10 AM
Originally Posted by TomZ
Tom,
Roger that...I have sent the same request to the machine shop, Thanks!
Ps-Happy Birthday!!!
