Bravo XR -
Trying to educate myself - I think I have the old style XR's. They are not the swept back style.
Who sells used ones that's reputable?
I lost forward gear in mine (when I drop it in gear there is a clunk and it kills the motor, then gets stuck in fwd and wont come out). Drained the oil and it looks like I have very small metal shavings throughout.
Will rebuild this one and keep as a spare, but would like to salvage my summer.
Anyone got one lying around they want to sell reasonably?
How hard are these to rebuild yourself?
There not hard at all to rebuild IF you are used to rebuilding Manual transmissions, rear axles etc and willing to buy whatever specialty tools you need, assuming you already own a arbor press, hydraulic press, bearing press plates, pullers, dial indicator, zero to 30 or 50" lbs tq wrench. All comes down to setting depth, preload, backlash, rolling tq.so real similar to doing a differential, Smitty
As far as "reputable" used ones, the majority of used XRs for sale were behind moderate to big hp. Ive had more then one person tell me they run a xr until its starts to shed metal, then buy a new one before it fails completely so I think youd be better buying one thats been professionally gone thru vs rolling the dice, Smitty
We sold two "used" XRs this spring. The gears, cases input and prop shaft were used but in great shape. Bearings, seals, races and upper shaft were brand new. Thats the only way id ever sell a used drive.
Thanks. Brad.
I have my doubts about rebuilding a "blown up" Bravo. Seems to me the cases get tweaked and they just do not stay together. Maybe I am wrong.
Catch them before and it is different but XR gears still are chit.
I would agree, for the most part. If gears have sheared teeth and attempted to climb over themselves, there is no way you can just replace the gears, bearings and seals, and expect the drive to last. Case material HAS been displaced. Those bearing and seal pockets are going to need closely inspected, at the very least, and likely welded in and re-machined, and the whole case would have to be dye penetrant tested before reassembly. There is undoubtedly a very high likelihood the case would be too far gone to save.
Thanks. Brad.
Wildman,
Thanks. Brad.
Thanks. Brad.
You are in the biz, how much cost would you have into inspecting and then repairing a bad case?
Exactly what I was thinking, I do not think many will do a dye penetrant. And really when you start coming down to it when that much damage has happened does it make since to pay for the machining and repair?
It would be out of the question for me. I don't have any fixturing to hold them, which would be an absolute necessity. For someone like AADS, who, I would think, would have the necessary fixturing, I wouldn't think it would be a real hill for a climber. I also don't know what a case would cost. The question is whether you could find a bare case, or a complete used drive that would otherwise be rebuildable. Sometimes, it comes down to what you have over what you wish you could find. I am of the opinion that nearly everything is repairable, if you don't have any other options. Looking forward at my long-term goals (fantasies), I don't think I would opt for an XR at all. If I need more than I can handle with an X, I'll just go with an SC or an SCX. But if my boat had come with an XR, and I needed to cobb it back together, for lack of options, I'd probably be pretty willing to go to the expense of making sure the case was as sound as I could make happen.
Thanks. Brad.
I found a solution with a relatively local guy.
Fortunately I only lost a bit of one tooth on the input gear......
Going to rebuild. Fingers crossed I'll be back boating sooner than later....
