Water pump cap/block plate >
Old 08-12-2023 | 02:13 PM
Default Water pump cap/block plate
Anyone know if I can just cap off the the fuel pump attachment to the water pump? Going electric fuel pump delivery. I’m assuming I can put some crank case oil in it then cap it with a plate.
Batmeat is offline
Old 08-13-2023 | 09:09 AM
Active Streak: 30 Days
Yes you can. I would use gear oil, like Bravo1 gear lube. There are roller bearings in there pressed onto the pump shaft.
Helmwurst is offline
Old 08-13-2023 | 09:32 PM
https://www.cpperformance.com/vsearc...%20block%20off
Griff is online now
Old 08-14-2023 | 08:34 PM
Awesome! I figured I didn't even think about using the Bravo 1 gear oil. Thanks you guys!
Batmeat is offline
