502 Mag Oil Sender wire question. >
Old 08-14-2023 | 11:32 PM
Default 502 Mag Oil Sender wire question.
Long story short, port motor oil has a press to fit sending wire on the oil psi sender. Stbd motor sending wire has an eyelet with a crush washer and a tiny nut. Needless to say the press to fit is 1000% times easier to get on and off.
Will this work? Thats all my Googlefu is coming up with after scorching my arm and torso trying to tighten that stupid nut.
https://www.ebay.com/itm/272099180726
Shorter story: Low oil pressure traced to either a weak sender or bad wire. Either way, when I hooked up a mechanical gauge, I picked up 10psi across the board, so Ill take the win. (37-43psi from 1,000-3,000 RPM).
lear60man is offline
Old 08-15-2023 | 11:19 AM
Sonic30ss's Avatar
Wow dude it says FORD right in the ad..... do not substitute auto parts for the correct marine parts SMH
Sonic30ss is offline
Old 08-15-2023 | 01:36 PM
Wow DUDE, like there's something specific about a wiring pigtail in a marine app versus automotive. SMH/WTF
Hint: There isn't!
Anyhow Learman, what you linked should work given the ID is matched to your stud.
I suppose every one of that style is consistent/standardized.
Further here is part numbers and links to various "brands".
You I'd guess have a Napa local if that's the way you want to go.
Better value for the 50 cent part it is.
Delco 12112171
Napa Echlin EC104
Dorman 85845
https://www.rockauto.com/en/moreinfo...sn=722&jsn=722
Amazon Amazon
https://www.napaonline.com/en/p/ECHEC104
But oh no they say coolant not oil. OMG
cheech is offline
Old 08-15-2023 | 10:14 PM
Thanks yall. Sonic is giving me a hard time because...well.....he is like that haha.
Im just happy to have dodged a financial bullet.
Old 08-16-2023 | 10:59 AM
Sonic30ss's Avatar
Hint: There isn't!
Delco 12112171
Napa Echlin EC104
Dorman 85845
https://www.amazon.com/Universal-Tem.../dp/B06ZYM4HCW
Yeah it was a joke! I figured someone would overreact.....nothing more than one friend busting on another.
Old 08-16-2023 | 01:28 PM
I sure missed the sarcasm.
You never know, there are some on here that are "Marine" only part goons at times.
cheech is offline
Old 08-16-2023 | 01:30 PM
SB
Winter time you’ll get a lot more reactions.
SB is online now
Old 08-16-2023 | 02:28 PM
Sonic30ss's Avatar
Paint it white or black, double the price and its magically a marine part.
Old 08-16-2023 | 02:41 PM
SB
and then, we have metallic blue paint
SB is online now
Old 08-16-2023 | 06:26 PM
Wait....wut? They come in blue? But seriously....that nut/washer combo is just asking to be dropped into Narnia.
