TRS Trim pump
Old 09-05-2023 | 02:04 PM
Default TRS Trim pump
Looking for a TRS trim pump, off a 76 donzi 18. I'm in Aurora IL
Slowmotion1 is offline
Old 09-12-2023 | 02:45 PM
The current pump is I think the prestolite style? It has a squareish metal reservoir on the bottom. Can I use a bravo or alpha style pump? Not sure if the lines are compatible? This boat only sees a few hours a year if that. Any direction or advise is greatly appreciated. Thank you
Old 09-12-2023 | 03:08 PM
rws's Avatar
rws
My 77 280 TRS 20 cig had the OILDYNE trim pump with a manual release valve so you could raise or lower the drive if pump failed.
I am pretty sure that the fittings are different on end of hyd hoses between prestolite and oildyne pumps.
i would think that a readily available olidyne pump from a newer boat could be adapted
rws is offline
Old 09-12-2023 | 03:41 PM
Photo, please
Markus is offline
Old 09-15-2023 | 08:50 AM
Old 09-15-2023 | 08:51 AM
Sorry I took so long to post pics. It's not my boat, just helping a friend. Just got the pump out last night. Thanks Again!
