View Poll Results: Do you winterize your boat?
Yes, I live where there is a high risk of freeze damage if I don't.
51
86.44%
No. That has to suck!
8
13.56%
Voters: 59. You may not vote on this poll
Do you live where you have to winterize your boat?
Obviously here in the Midwest one has to winterize, and I always get ribbed by my friends who live where you DON'T have to do this. Making a poll.
Baja 252 Islander
Baja 252 Islander
I’m in VA so I get to winterize, hunker down for hurricanes and deal with Nor’Easters.
honestly though - winterizing takes less than 10 minutes and costs about 40 bucks. No reason not to - sleep better and get corrosion protection.
the day I take my boat out i winterize, change oil and filters and drive lube. Couple hours and I’m ready to go the next summer. Change plugs every year over winter and wait on doing water pumps every spring so they don’t sit and get warped all winter. Fuel filters in spring also….
I have a sump pump I bought from Harbor Freight. It has afloat switch on it (which you see hanging over the side).
hose runs down to the fresh water flush.
son lifts up the float switch, once it starts coming out the drive (usually a second or two) I fire the motors up. Normally runs about 7-10 seconds before the motors are filled and it’s coming out the exhaust/dumps. Kill motors and pat myself on the back……
(sounds like you might not have a fresh water flush, which is not much more than a T into the intake line before my sea strainers)
PS, that pink anti freeze always shows up in Walmart starting in October or so for 2-3 bucks a gallon. I normally buy 12-15 gallons. I’m fresh water cooled though so I could probably get away with 7 or 8 gallons….
Thanks for the reply. I did buy my pink stuff from Walmart funny enough in October. You are correct that I don't have a fresh water flush system. Never saw the need because I run only in fresh water. So in winterizing, you still run through the sea pump and thermostat or do you have a by-pass installed? I was thinking that the "colder" anti freeze I was running through the drive shut the thermostat and the anti freeze I was sending in just went out the exhaust and the engine was left full of mostly water.
In my Cafe Racer I never ran stats - I went the bypass route, largely because without a stat I knew I was always getting a good flush. I still got oil temp just never really had any water temp to speak of…..
fresh water flush is nice though if you’re wanting to run on the hose - no need to worry about muffs…..
just to say it out loud, I’m a Bravo boat so no impeller in the Outdrive
I winterize in Maryland. After doing the antifreeze method and losing a set of heads to cracks I asked a guy in Alaska what do they do. His reply, air dont freeze. Today I drain the exhaust manifolds and blocks and pull the big hose off the water pump. All done. 20+ years never an issue.
