5 minute 4hp+ per ci marine engine dyno pull >
Old 10-30-2023 | 06:38 PM
Default 5 minute 4hp+ per ci marine engine dyno pull
How hot does that dyno get?
Old 10-30-2023 | 07:14 PM
Love it!!
I get nervous on a standard pull, 5 minutes I`d lose my lunch lol
Endurance is definitely hard on engines. That has to be some serious cylinder pressure in a small ci engine.
ICDEDPPL is offline
Old 10-30-2023 | 09:28 PM
in the 40s during the war one of the aero engine company's i think it was Pratt and Whitney took a 3350ci radial that made 2500hp and for the fun of it cranked the boost way up to see how long it would last it made over 5000hp and ran non stop for 30 days then shut down they found nothing out of ordinary for wear now thats amazing and impressive!
Old 10-30-2023 | 09:36 PM
BBYSTWY's Avatar
Read about that motor several times...If I remember correctly maybe it was a different one they drained the oil out of it to try and kill it and it still lasted like 2 hours or something crazy
BBYSTWY is offline
Old 10-31-2023 | 07:12 AM
Knot 4 Me's Avatar
I think the 3350 was a Wright? The P&W Double Wasp was a bad a$$ engine.
Nelson builds bad a$$ stuff.
Knot 4 Me is offline
Old 10-31-2023 | 10:25 AM
Tom builds incredible packages. Would love to have him, or Steve Morris, build me a big block. I am actually shocked that the turbo exhaust side didn't get glowing hot. I know the exhaust manifold was water cooled, I wonder if the heat sync effect from that is enough to keep the turbo exhaust housing alive.
mutt2jeff is offline
Old 10-31-2023 | 02:57 PM
I`m just a dummy not an engine builder by any means but over the years Ive added things I hope help an endurance engine..... piston and spring oilers, coated pistons, .904 lifters, belt drive, shaft rockers, comp cams marine easy on the valvetrain cams, also cooling the fuel on the way back to the tank, dedicated sea pump stage just for intercooler , extra oil cooler, 2 sea pump stages for engine, Flex fuel E85, 16 injectors, 8 at the intake ports.
I`ve also thought about a 55mm cam and coated exhaust valves.
Unfortunately all that is insignificant if the tune isn`t right .
ICDEDPPL is offline
Old 10-31-2023 | 03:59 PM
F-2 Speedy's Avatar
wast of money, those aren't Pro stock engines.........
F-2 Speedy is offline
Old 10-31-2023 | 08:31 PM
Love it!!
Looks like 15 lbs of boost on 260ci. That's making some good power for that size.
I had my sbf at 31lbs on 9:1. I was scared, but it took it no problem lol.
underpsi68 is offline
Old 10-31-2023 | 08:32 PM
Some info on the engine;
