2000 gmc 6.0 no start
Fuel Injector fuse? Being a plow truck has it sat for a while where rodents could have got at some wires? You should be able to see 12 volts at the injectors
Have you checked for any codes? Really the only 2 sensors that won't make it start are crank, and coolant temp. It should still fire with all other sensors being faulty.
😂. Ain’t got not gas in it. It did sit all year (first year with plow attached) so I didn’t have to trouble shoot that dammm thing. But yes sat. Cked fuse box first and relay/fuse and all good. No signs of chewed up wires at all but will confirm in the not so visible areas. What psi do the injectors need to see?
I’ll confirm the 12 volts to injectors tomorrow.
So with that said and fires with ether? I’m stumped a bit. Regardless first year I leave plow hooked up and that functions just fine and now the cocsuker just decides not to start. The way it goes. 😂 lol
I'm quite certain a 5.3 should start without the mass air flow, or cam sensor hooked up. I forgot to plug my cam sensor back in once and it would still run fine, just back fire once in a while on startup. With the Mass air flow disconnected, i thought the ECU had default parameters it just went to.
Ive got a 6.0 in my van that is giving me trouble starting. Thought it was the fuel pump again. If I turn the key to "start" right away it wont start very well if it starts at all. If i turn the key to "on" and wait 3 to 5 seconds it starts normally. Mine has about 330,000 miles on it.
