Water pick ups >
Water pick ups
Water pick ups
Old 11-06-2023 | 03:53 PM
splashandburn's Avatar
Default Water pick ups
I'm in the process of adding water pick ups for Whipples. I can't go thru the transom so I'm going to have to go thru the bottom of the boat. My question is how to I seal everything up once I go thru the bottom? The pick ups themselves don't have a flange or anything outside the hull so once I put an 1-1/4" hole thru the bottom how do I seal up the tube sticking out the bottom of the boat? Any help (and pics) would be greatly appreciated.
splashandburn is offline
Old 11-06-2023 | 04:11 PM
Never seen a thru hull pickup without a flange. My 43 Black Thunder has the pickup pipe hole filled and the escutcheon flange set in 5200.
Topshelf38 is offline
Old 11-06-2023 | 04:38 PM
Attached a photo. There is a flange but only on the inside of the boat - nothing goes outside.
Old 11-06-2023 | 04:42 PM
That seems insanely too long.
ICDEDPPL is offline
Old 11-06-2023 | 04:57 PM
They still need to be cut. Just received them from Teague.
Old 11-06-2023 | 06:41 PM
Rookie's Avatar
I'd cut the hole. Then I'd resin over the cut and exposed glass. Then I'd seal the flange to the hull with sealant of choice. I'm not a fan of 5200 because of how runny and permanent it is. Maybe 4200 is thicker.
Rookie is offline
Old 11-06-2023 | 07:36 PM
Inwas planning to resin or epoxy over the exposed cut and was thinking of using MarineTex to seal it all in. Itl be pretty permanent but I don't see how else to.seal of all up really well.
Old 11-06-2023 | 07:38 PM
So I'm assuming your flange is on the inside of the hull, not outside?
I'mdoing this on a 46 Black Thunder
