Ccw rotation bottom mount starter p/n? Mercrusier >
Old 01-31-2024 | 09:45 AM
Default Ccw rotation bottom mount starter p/n? Mercrusier
As the title suggests I need the part number for a Merc (5.7) Reverse Rotation (RH) BOTTOM MOUNT Starter.
Any help greatly appreciated,
Thank you
GLENAMY 242SS is offline
Old 01-31-2024 | 08:36 PM
Your title is a little confusing because CCW usually refers to a "normal" rotation engine. Reverse rotation is considered CW. Engine rotation is stated when looking at the flywheel end.
A 'normal" car or truck V-8 would be considered CCW rotation.
If you are looking at the front of your engine which way does it rotate ?
BillK is offline
Old 02-01-2024 | 08:53 AM
Thank you for your input and you are correct about engine rotation, however, as for starter rotation ccw is for a reverse rotation engine.
I should have stated a reverse rotation engine for clarity, oh well.
Anyway I figured people on here would understand a standard rotation situation would be a breeze, I found a reverse rotation one on Hardin only to find they no longer carry it. I was able to track down exactly what I needed after a day on the computer it is on it's way..
Thank you for your clarification..
