Cam recommendations 572 blower
Looking to cam up a 572 dart, hyd. roller, 345 heads Merlin, valves 2.3 I / 1.88 E, procharged 6-12psi, 1400 Dominator, 6500 redlined, 26' 4000 lb. American Offshore catamaran. Guessing around 112, 264 dur, 680-720 lift. Those are just some random suggested specs. IDK. TIA Anyone got a similar setup and love how your cam rolls, let me know what you love and why.
Are the 345’s cnc’d or ported? I wouldn’t go to crazy on lift. Duration seems in the ball park. Ck out the comp lobes icdedpple had or has in his 548 builds if you get a chance. If you can’t find the thread via search let me know or he’ll likely chime in.
If you’re heads are stock I think their gonna be a choking point. JMO
Just for comparison only but still a good read!! Try and copy and paste. Cam below was one Dan jones spec’d however I don’t believe he went that route… can’t keep up with him! lol. I will say the cams he spec’d and ground for my na 565’s are spot on and very easy on the valvetrain and make awesome power all the way through!!!!
https://www.offshoreonly.com/forums/general-q/374052-tunell-raaammm.html
Though my readings here on OSO, I think the consensus is that a 4.375" stroke is better for a marine application due to rod angle and prolonged high RPM running. Many here advocate for nothing above a 565 for this very reason.
Thanks. Brad.
