Dead battery / Can't open engine cover >
Old 04-17-2024 | 05:05 PM
Exclamation Dead battery / Can't open engine cover
After two days of plugged in shore power, my port motor battery is still dead. The starboard and center motor battery are charged at 12V on the console gauges and all 4 battery disconnects are on.
The engine hatch is not working, Assuming the engine hatch is wired to the dead port motor battery.
How do you get power to open the engine hatch if that battery is shot?
AZBAJA is offline
Old 04-17-2024 | 05:55 PM
There will be a remote battery connection under the rear seat or similar area, typically.
Baja 252 Islander
bajaman is offline
Old 04-17-2024 | 06:07 PM
Noted: I'll look for that
Thanks!! .
AZBAJA is offline
Old 04-17-2024 | 06:11 PM
jeff32's Avatar
Worst case open from the back hinges of the engine hatch!
jeff32 is offline
Old 04-17-2024 | 06:29 PM
It's been my experience that these piano hinges are often 'trapped' inside the hull...meaning no access from the back.
Baja 252 Islander
bajaman is offline
Old 04-17-2024 | 06:31 PM
Thanks!! .
Also, what year? From about 2000 on, maybe slightly before, they made the 'slider' on the hatch ram have some travel in it, to where you can usually lift the hatch (they ARE heavy!) enough to get your arm through with a ratchet and socket, and take out the bolt that secures the hatch to the ram.
Baja 252 Islander
bajaman is offline
Old 04-17-2024 | 07:37 PM
jeff32's Avatar
you may be right... on my sonic there are4-5 exterior hinges so it is very easy to do...
jeff32 is offline
Old 04-17-2024 | 07:59 PM
Kefurr's Avatar
my 2000 is the same setup as yours
Kefurr is offline
Old 04-18-2024 | 12:57 AM
If the hatch ram is not on a relay, you can just apply 12 Volts to the back of the hatch switch
Griff is offline
Old 04-18-2024 | 06:12 AM
AZBaja,
If you can't find a way to directly apply 12v to the lift jack, check to make sure you can't just lift the engine hatch by hand. The lift jack on our PQ is not actually held to the hatch by a pin. It's heavy as farq, but I can lift it, and we keep a "stilt" in the engine bay, off to the side, for popping it up, in the event of an issue. Short of that... I've heard of people removing the cover or grill, going in through a side vent and pulling the pin holding the hatch to the lift jack with a hook. Hopefully, it's a detent pin and not held in with a cotter pin.
Thanks. Brad.
Brad Christy is offline
