Seeking 575SCI Info
Old 04-28-2024 | 02:41 PM
Default Seeking 575SCI Info
I’m looking to get input / pros and cons on the 575’s. I’m looking at a pair that are fresh rebuilds along with fresh rebuilt blowers from DMPE. Just looking for some input from ppl who have experience with these engines. I’m aware of the Eddie Young throttle body upgrade which is something I plan on doing. Is there anything else to know about or lack of parts availability with them? TIA
Mtb_05 is offline
Old 04-28-2024 | 02:46 PM
jeff32's Avatar
I dont have any experience with them, right or wrong, i would be hesitant to run those only from what i heard or read... subscribed to know more
jeff32 is offline
Old 04-28-2024 | 11:18 PM
Good engines. Basically a 502 TBI version of the 525SC. Pretty mild with Low compression, low boost and small cam. Like most roots SC engines, they are thirsty.
Griff is offline
Old 04-29-2024 | 01:34 AM
Hey Griff,
thank you for the reply! These are now 509’s with hyd roller cams, dart 320 heads. Do you know of any parts availability issues?
Mtb_05 is offline
Old 04-29-2024 | 09:41 AM
I loved the one that I had. In stock form they have a flat tappet cam and iron heads. That looks like it has been addressed with these builds.. I believe the injectors are NLA, but with the YPM throttle plate update that isn't a problem. If DMPE just went through the blowers, I wouldn't be a bit afraid of them.
snapmorgan is offline
Old 04-30-2024 | 02:00 AM
Originally Posted by Mtb_05
Hey Griff,
Best thing to do is go to mercruiserparts.com and see what is NLA.
Griff is offline
Old 04-30-2024 | 06:32 AM
Quinlan's Avatar
Finicky and Thirsty.
Brad Smith punched mine out to 509's and with a few other mods were close to 800HP. HP Mafia did the last tune, and they were more trouble free than ever.
What drives do you have?? plan on upgrading lol
Quinlan is offline
Old 04-30-2024 | 06:44 AM
So you’re running factory TBI? Haven’t upgraded to Eddie Young upgrade? Have read and spoke with him directly and it’s supposed to make a big difference. I have XZ drives they will be fine
Mtb_05 is offline
Old 04-30-2024 | 09:30 AM
So I was Eddie Young's guinea pig for the 575 throttle body/ injector plate setup. The prototype and tuning was done with my engine. Pretty much the only 575 specific issues that I had with mine in stock form was dripping injectors and it would need an IAC valve annually. The injector problems are solved with the new injector plate. It ran perfectly after the upgrade. I ended up building mine with a roller cam and brodix heads. The last time it was on the dyno, I believe it made around 760 hp with a smaller pulley. Overall a great engine and I never had any problem with sourcing parts. The sensors are the same as the rest of the Merc EFI engines and are also available from GM or auto parts stores. It uses a standard EST distributor that is available everywhere. I wouldn't hesitate to own a pair of 575's personally. I really like them for their simplicity and ease of upgrading.
Old 05-05-2024 | 11:05 PM
Intake manifolds get eaten up. I just replaced both of mine "got them from Hardin Marine"-Merc is NLA. I have had two boats with them and have no major complaints--super chillers and Whipples bring them to life.
Joe
JPEROG is offline
