Edelbrock 1410  question >
Old 05-02-2024 | 11:13 AM
Default Edelbrock 1410 question
Hi, I put a Edelbrock 1410 carb on my 7.4l mercruiser and I have one problem. To get the engine started I need to set the idle screw at a too high rpm. But if I back off on it to get rpms down to a 600-700rpm idle and then shut off the engine it won't start back up. ( unless I do the too high idle adjustment as initially mentioned). What do I do to have it start and run at a lower normal idle? Thanks
Jase is offline
Old 05-02-2024 | 04:29 PM
SB
Do you have one control lever and if so, do you know how to put throttle lever in neutral while still being able to give engine throttle ?
SB is offline
Old 05-02-2024 | 04:44 PM
Yes one old quicksilver lever that does both throttle and engages the forward or reverse simultaneously. Although there is a disengage button on the side that will allow me to give throttle in neutral. Why ?
Jase is offline
Old 05-02-2024 | 04:59 PM
SB
So you can do that to start it, then when engine warm , pull lever back so engine idles and you can then out into gear. Pretty normal for carb’d engine.
Or am I misunderstanding ?
SB is offline
Old 05-02-2024 | 06:02 PM
No I think you have a good idea there. There was a Fitech EFI throttle body there before so I never considered using that button. This might work. On my previous boat I had a 7.4l with the quadrajet carb. But it was set up with a gear lever and a throttle lever . So I can't remember but you think generally in that scenario we coax the start and idle by touching the throttle lever ? This would make it all make sense by using that button....
Jase is offline
Old 05-02-2024 | 06:15 PM
SB
That’s why it’s (button) there.
You must be young enough you never used a carburetor ?
The term two pumps and a shoulder roll does not just pertain to sex. Lololol It is also a reference to starting s carb’d motor. Two pumps is pumping the throttle lever forward twice and leaving a hair forward to run at say 1k rpm until engine warm enough to back off throttle and idle in neutral (about 700rpm) on it’s own.
SB is offline
Old 05-02-2024 | 06:23 PM
F-2 Speedy's Avatar
LMAO......
F-2 Speedy is offline
Old 05-02-2024 | 06:41 PM
Ya I was doing different pumps thank you very much. It's so obvious after you mentioned the reason for that button.....
Jase is offline
Old 05-03-2024 | 05:15 AM
articfriends's Avatar
LMAO......
Ive heard the term "two pump chump", never two pumps and a shoulder rolll!
articfriends is offline
Old 05-03-2024 | 04:14 PM
Evolution...
Tartilla is offline
