Bilge lighting?
What have you guys done in terms of lights in the bilge ? I thought about machining up some brackets and using “ rock lights “ like I used to do on my crawlers years ago with 3-4 different color settings. What are your suggestions? For my ol Cigarette Cafe Racer.
i used the underbody style thats in tube, https://www.ledunderbody.com/led-underbody-light-kits/ ended up being expensive after adding the extra tubes etc but being its in the tube its easier to mount them, the tape style i would stick them to some aluminum strips then attach them to the fiberglass/
I bought this for the trailer, ended up around 800 in it 75ft
sorry for the lg piks
it helps when its a smooth surface, all my mirrors has the 3m tape , have to break them to get them off
5952 3M VHB Heavy Duty Mounting Tape
In hard to bond with tape places or places that will get abuse I use 3m weatherstrip glue. put it on where you want something, put it on the something, let them dry a bit and then attach them. It works really well and can be removed if needed, it just sucks removing.
