LS style throttle bodys
Old 05-05-2024 | 11:22 PM
Default LS style throttle bodys
has anyone tried running dual LS style throttle bodies on top of a root blower? they seem to flow as much if not more then a 4150 style throttle body.
LTZCrew is offline
Old 05-06-2024 | 07:00 AM
many its called a blower hat about 5-7 grand for a carbon fiber one with red butterflies
boostbros is offline
Old 05-06-2024 | 12:22 PM
are you talking about a bug catcher?
like this?
https://www.ebay.ca/itm/154485586657
im meaning like running a adaptors to go from a 4150 carb or 4 barrel throttle body to a GM 4 bolt 105MM motor blade
LTZCrew is offline
Old 05-06-2024 | 01:02 PM
they make them in billet and i think there called toilet bowls not sure on that though i have seen big billet single or 2 of them on a blower
Old 05-06-2024 | 04:40 PM
I have some brand new billet 4500 throttlebodies.,was gonna use them on my side mount whipple set up.then I sold the motors.have some killer double swap gen 6 cams too
sutphen 30 is offline
Old 05-08-2024 | 12:53 PM
I know what you are saying, and I haven't seen it.
This is the closest thing to a production piece that exists to my knowledge.
https://www.alkydigger.net/product/EN1014-B1.html
Precision is offline
Old 05-08-2024 | 08:14 PM
Rookie's Avatar
I believe I created a file that I merged a 4150 and a LS flange together. I was going to 3D print adapters for what you are looking to do. Haven't looked for the file in a while.
Rookie is offline
Old 05-09-2024 | 11:54 AM
yah, that is what i was thinking Rookie, i found some that Holley made, so figured id give them a shot
LTZCrew is offline
Old 05-09-2024 | 12:24 PM
BBYSTWY's Avatar
Only issue I could see is having to add fuel rails above the blower as well since we are talking roots blowers....they need fuel running through them...I strongly considered this on mine as holley makes an add on fuel rail that mounts to a 4150 flange but it was far more cost effective to just run terminator "throttle bodies"
BBYSTWY is offline
Old 05-09-2024 | 03:19 PM
ive got TBS efi plate so the blower will be wet
i was looking at going over to the terminator system, after talking to holley it was cheaper to keep the HP system, get a plate and the adaptors. i wish the terminator was plug n play. would have been way easier:P
LTZCrew is offline
