Cig interior guys >
Cig interior guys
Cig interior guys
Old 05-15-2024 | 02:51 PM
F-2 Speedy's Avatar
Default Cig interior guys
So whats the trick to getting to the top mounting stud the nut came off, the 5 inch tube that carries all the wires and cables is just underneath it
TIA Speedy
F-2 Speedy is offline
Old 05-15-2024 | 09:55 PM
cant reach in from the engine bay?
88bullet is offline
Old 05-15-2024 | 10:06 PM
F-2 Speedy's Avatar
Id have to remove the back seat
Old 05-16-2024 | 06:16 AM
cigrocket's Avatar
I took ratcheting box wrench, a piece of aluminum length, secured the 2 together with some hose clamps and bent it enough to get in the hole and used it as an extension.
cigrocket is offline
Old 05-16-2024 | 09:29 AM
F-2 Speedy's Avatar
I took the the handle off then removed the lower stud, pulled the lower panel out far enough to get a lock washer and nut on the top stud, then reinstalled the lower stud in the handle, Im going to try your ratchet wrench extension thingy to tighten the top nut.
Old 05-23-2024 | 06:31 PM
F-2 Speedy's Avatar
Right you are Sir........worked like a champ..........
Old 05-24-2024 | 06:44 AM
Now how do you get the nut back ON?
Baja 252 Islander
bajaman is offline
Old 05-24-2024 | 09:42 AM
F-2 Speedy's Avatar
its all done, I got the washer and nut on by going in between the two panels before installing the bottom stud and nut.........what a PITA
