Fuel Filter on CARTER CARB >
Old 05-31-2024 | 06:55 PM
Default Fuel Filter on CARTER CARB
Ok i have a 29 Powerquest with 454s and they have Carter Carbs. Has anyone have ever changed the filters that are in the Carb ?
It soes not look like a hard job curious ?
thanks.
Steve The Oil Guy
powerqrudy is offline
Old 05-31-2024 | 07:10 PM
most carter carbs do not have a filter per se. they either have a screen behind the inlet fitting or they have a small screen on each needle seat.
compedgemarine is offline
Old 06-01-2024 | 11:35 AM
OK, that is a start.
Thank you for you insight.
Steve
Old 06-02-2024 | 09:17 AM
Ayuh,.... The important "trick" is to use 2 wrenches,.....
​​​​​​​One to hold the carb's fitting, 'n one to turn the line's nut, preferably a line wrench,....
Bondo is offline
Old 07-20-2024 | 03:31 PM
very important
splashandbun is offline
