Air condition weight >
Old 06-05-2024 | 02:02 PM
rvtransport's Avatar
Default Air condition weight
Anyone know how much dock side air condition weighs installed in the boat?
rvtransport is offline
Old 06-05-2024 | 05:34 PM
What is a dockside airconditioner?
ICDEDPPL is offline
Old 06-06-2024 | 08:55 AM
I guess I should just say air conditioning. It is factory installed in my 2009 Fountain. It has a water bump in bilge that draws from sea strainer and compressor and ducting is mounted in port side cabin. The reason I ask is my boat has a slight list to port side and figured it could be weight of AC? There is also stereo with amps in same cabinet along with seems to be very heavy counter top cabinet with sink. This is the new interior only in 2009 and 10 42 Fountains before the went under. It seems to run bow heavy compared to my previous 2006 42.
Old 06-06-2024 | 09:46 AM
Wally's Avatar
Were doomed!
Depending on what size the AC system is i'd venture to guess the unit itself is between 40-50 lbs and the pump assuming its a March LC-3 is right around 6.5 lbs
-Wally
Wally is offline
Old 06-06-2024 | 10:05 AM
That is lighter then I thought. Thank you!
