aluminum head and head gasket info needed >
Old 12-05-2002 | 09:02 AM
traviss's Avatar
Default aluminum head and head gasket info needed
When running a aluminum head is there a specifc head gasket your suppose to use? A specific material?
Or can I just use the same style( rubber coated steel shim) I used with my iron heads.
Travis
traviss is offline
Old 12-05-2002 | 12:26 PM
Ratchet's Avatar
Ok, had to try out a new icon..........
Every one of the manufacturers of head gaskets has recommedations.
Here's an example:
http://www.rolmfg.com/Technical/Performance/HG_Tech.htm
This is a list of gaskets from ROL
Ratchet is offline
Old 12-05-2002 | 04:45 PM
DanB's Avatar
Charter Member #71
Travis
Felpro , and ARP studs or headbolts..do that and torque em right and you'll never look back.
Dan
DanB is offline
Old 12-05-2002 | 05:55 PM
blue thunder's Avatar
Sorry traviss... its me muchin off your thread again. is
Are ARP's head bolts ok for reuse? Got a pile of them and don't want to buy new unnecessarily.
BT
blue thunder is offline
traviss's Avatar
thanks guys. I didn't research before I posted, but PAW catalog listed most felpro head gaskets. They listed everything I needed to know and said if they worked with aluminum heads.
Thanks again bros
Travis
traviss is offline
Old 12-06-2002 | 02:39 PM
bobby daniels
BT
ITS BY FAR BETTER TO USE NEW BOLTS BUT IF YOU CLEAN THREADS AND THE BOLT STILL STRECHS WHEN YOU TOURQE IT,, IT WILL WORK ,BUT DAMN WHY GAMBLE ?? DO IT RIGHT THE FIRST TIME AND DON'T AS THEY SAID (LOOK BACK) !!!
FEL-PRO HAS KILLER GASKETS MADE FOR ALUIM HEADS AND IT DOES TAKE A SPECIAL GASKET
Old 12-06-2002 | 06:35 PM
merlin540
have your machine shop cut receiver grooves in your head and run a 1012 felpro headgasket. they will take a lot of boost and i have used them since they came out with no problems
ur2slo
08-17-2006 10:01 PM
z.zuperboat
1
02-16-2006 08:38 AM
boat4life
0
04-27-2004 11:11 PM
PatriYacht
18
03-28-2004 06:33 PM
BryanTuvell
11-10-2002 10:56 AM
