2005 Merc 4.3 stalling >
Old 07-22-2024 | 12:35 PM
Default 2005 Merc 4.3 stalling
I have a 2005 MerCruiser 4.3 MPI. The motor stalls after acceleration or when comes back to idle
The following have been done
1 computer hooked up and fault codes showing are 94 which is a Pitot Pressure circuit which can not be cleared. Don’t think this is the problem
2 changed out IAC twice and is working properly along with new screen but you can unplug and plug back up with me difference. Getting 12 volt at the plug-in
3 new fuel pump with 40 psi
4 timing set
5 Injectors cleaned
6 new dist cap rotor plugs
Any help would be appreciated
Stevetillis is offline
Old 07-22-2024 | 07:10 PM
SB
Please explain this clearer and with more detail “but you can unplug and plug back up with me difference.”
SB is offline
Old 07-22-2024 | 09:24 PM
what are the iac counts when idling?throttle blade may need to be opened or cleaned.
sutphen 30 is offline
