2007 Mercruiser 496 H.O Correct Head and Engine Gaskets To Use? >
Old 07-27-2024 | 02:08 PM
Default 2007 Mercruiser 496 H.O Correct Head and Engine Gaskets To Use?
I have a 2007 MerCruiser 496 425 HP with an OM serial number prefix.
What is the part number of the correct head gaskets to use? Can you use Fel-Pro? Genuine Merc part numbers to use are?
Also, complete engine gasket kit part number?
Thomasg49946 is offline
Old 07-28-2024 | 10:13 AM
Default 496 gaskets
Hi, just redid a head on my 496 ho and used napa for felpro head gasket($40 compared to mercury $248) and valve cover gasket($21.95 for both sides compared to mercury over $250 for one side) and intake gasket ($109 compared to mercury $275). Get heat exchanger seals, thermostat and seal, and exhaust manifold gasket (one piece)from mercury. I have the napa part numbers if you want them. Todd
989-289-9240
Todd B. is offline
