Bravo one Trim motor issue >
Old 08-04-2024 | 08:54 AM
Default Bravo one Trim motor issue
Yesterday I discovered my drive will not go up. Stuck in the down position. When you hit the up button at the helm it just clicks at the solenoid. When I jumped positive + to the blue wire on the trim motor, it sparked and obvious its a short to ground. Don't like getting sparks in the engine compartment!!! My first thought was bad up solenoid, but if I jump the wire the motor should go up, not spark and short out. correct?
redstinger is offline
Old 08-04-2024 | 09:55 AM
Correct
Markus is offline
Old 08-04-2024 | 05:27 PM
What happens with down? Did you disconnect all wires from solenoids? Do that before indicting trim pump.
BadDog is offline
