Merc 496 HO EFI Fuel filter? >
Old 08-11-2024 | 10:04 AM
Default Merc 496 HO EFI Fuel filter?
I have a pair of 496 HOs - got a bad tank of fuel and sucked crap through fuel separator (Aux) and into the engine mounted fuel filter. Replaced both, dumped old fuel best I could (tanks have baffles) and engine turns but never fires.I can hear the pump priming and it stops after a few seconds. Also check fuel flow so not vapor locked or tank vent related.
IS there another fuel filter I am not aware of like the sneaky one in a carb?
Hope I didnt clog up injectors somehow.
Swamplizard is offline
Old 08-11-2024 | 10:09 AM
F-2 Speedy's Avatar
did you fill the filter before reinstalling ?
F-2 Speedy is offline
Old 08-12-2024 | 06:25 PM
yes - and the one I replaced was full as well so fuel is pumping. I need to check electricals - replaced ignition since I lost a key (dont ask) in the drink. Might have a loose wire.
Old 08-13-2024 | 08:13 AM
NEw ignition switch is 1/4 inch longer than original as seems to be grounding out on throttle assembly behind the dash. Gonna take some boat yoga to get to it but hoping that is the issue - starter turns but possibly no power to engine cpu etc.
