Help identifying gear ratio for Bravo 1? >
Old 08-21-2024 | 04:45 PM
Default Help identifying gear ratio for Bravo 1?
Hi, I like to know gear ratio for my Bravo 1 / 377 MAG, bought as a complete unit 2014 by previous owner.
I have problems finding a prop that works for me, so I need to start finding the gear ratio for the drive.
Engine number is 2A443075
Drive number is 2A418704
Any one able to help me find that out?
I have seen in older posts someone have searched by the identification numbers.
Regards Retro2
Retro2 is offline
Old 08-21-2024 | 05:13 PM
Regards Retro2
Outdrive serial number should start with a '0'...
Mercruiser sterndrives and sterndrive information
Baja 252 Islander
bajaman is offline
Old 08-21-2024 | 05:27 PM
OK, thank you. Those numbers was what I could find in the insurance papers.
I'll see if I can find some more.
Retro2 is offline
Old 08-21-2024 | 05:55 PM
Mbam's Avatar
Offshoreonly Advertiser
Regards Retro2
The drive serial number you have is for the transom assembly. SEACORE BRAVO E T TRANSOM
The 2A for the serial is valid, they ran out of numbers that start with 0 a while ago.
Mbam is offline
Old 08-22-2024 | 06:10 AM
Thank you. then I have to find the numbers on the drive it self when my boat is out of the water.
You don't know if there is a "standard" gear ratio delivered with the 377 MAG?
Retro2 is offline
Old 08-22-2024 | 06:59 AM
If you pull the drive, mark the drive shaft and prop shaft. Rotate the drive shaft 10 times and count prop, then divide by 10
AllDodge is offline
Old 08-22-2024 | 01:35 PM
OK thank you, I do know about that. Just liked to try find out while the boat is still in the water.
Retro2 is offline
Old 09-16-2024 | 02:42 AM
Hello Bajaman, i want to ask you if you know.
One sterndrive like bravo1 that was in diesel engine with ratio 1,5 to 1 is the same with an other bravo1 that was in petrol engine with the same ratio?
Probelegios is offline
