525 rod  question >
525 rod question
525 rod question
Old 09-09-2024 | 08:01 PM
tripps's Avatar
Default 525 rod question
Have a 502 Shor t block w merc I beam rods what do all the numbers mean on side by rod bolts,what is minum side clearnce
tripps is offline
Old 09-10-2024 | 09:45 AM
F-2 Speedy's Avatar
Post a pic, are you talking about the rod and cap stamping 1 thru 8 if so its to keep them matched up and what hole they go in
F-2 Speedy is offline
Old 09-11-2024 | 09:51 AM
tripps's Avatar
Default Rods
That I know some have 153,244 0008,0908,trying to figure out to post pics
tripps is offline
Old 09-11-2024 | 10:18 AM
F-2 Speedy's Avatar
never seen that, click the square next to the smiley face to post pics
Old 09-11-2024 | 08:20 PM
tripps's Avatar
Default Rods
tripps is offline
Old 09-11-2024 | 08:21 PM
tripps's Avatar
tripps is offline
Old 09-11-2024 | 09:37 PM
F-2 Speedy's Avatar
Maybe grams of weight for balancing ? just a guess
Old 09-12-2024 | 09:06 PM
tripps's Avatar
Default Rods
If the 3 digit number is 153 and other rod is 244 that's 90 grams different in rod . You would think the rods would be closer tolerance being a high quality item t h a n k s
tripps is offline
Old 09-15-2024 | 11:17 AM
My guess is they are some serialization by the manufacturer of the rods.
Minimum side clearance? Whatever the service manual calls for. Or standard BBC specs.
cheech is offline
Old 09-15-2024 | 10:52 PM
Originally Posted by tripps
The small 4 digit number is the number for that production run. The larger 3 digit is the rod number in order of machining for that production run.
Smitty275 is offline
