Steering cable play? >
Old 09-16-2024 | 07:57 PM
Default Steering cable play?
When moving the drive side to side the housing on the steering cable moves away from the nut on the rack and then pulls back against nut when pushing opposite direction. Does this go away with engine running? Cable problem? Adjustment?
liberator221 is offline
Old 09-16-2024 | 10:16 PM
TomZ's Avatar
Try it with the engine running. The pump/pressure will remove the play (somewhat).
TomZ is offline
Old 09-18-2024 | 02:16 PM
Wondering that after started post. Thanks
