502 spring pressure >
502 spring pressure
502 spring pressure
Old 09-28-2024 | 06:06 PM
tripps's Avatar
Default 502 spring pressure
How much open pressure can GM h y d roller lifters handle,500lbs open? Under 6000 rpm
tripps is offline
Old 09-28-2024 | 07:07 PM
F-2 Speedy's Avatar
I think thats a bit much for a stock lifter, Id stay in the 400-425 range......the Isky 8005A is a good spring for a 500 525 efi rebuild, whats the cam specs ?
F-2 Speedy is offline
Old 09-28-2024 | 07:14 PM
tripps's Avatar
Default Cam
525 cam co u ld I run solid lifters on that cam?
tripps is offline
Old 09-28-2024 | 07:32 PM
F-2 Speedy's Avatar
I wouldn't, lobe profile is for hydo roller, why do you want to run 500 lbs springs with that cam ?
Old 09-28-2024 | 08:17 PM
tripps's Avatar
Default Cam
Just afraid of valve float
tripps is offline
Old 09-28-2024 | 08:31 PM
F-2 Speedy's Avatar
The rev limiter is set at 5350 on the 525 EFI 555 controller, if you want to spin it to 6k I might choose another cam
Old 09-28-2024 | 10:35 PM
GPM
Could run a short travel hydraulic roller lifter
GPM is offline
Old 09-29-2024 | 07:28 AM
cig28's Avatar
I’m running crower solid roller lifters on a crane 741 hydraulic roller cam which is similar to the 525 hydraulic roller cam with comp roller rockers. Lash is set @ 6.
cig28 is offline
Old 09-29-2024 | 08:57 PM
Rookie's Avatar
As long as it's a billet core you can run solids. 0.004"-0.006" lash to make up for the hydraulic "pre-load" before it goes solid.
I've run solids on hydraulics forever and when talking with Comp they had no problems and said it would be a great combination when I ordered my new HR cams.
Rookie is offline
Old 09-29-2024 | 09:25 PM
F-2 Speedy's Avatar
Is a stock 525 cam billet core ? ....
