26 Outlaw 496 mag ho prop questions
Hello,
I just bought a 09 26 OL. So this has a bravo 1 x drive and came with a bravo 28p prop on the boat and also had a spare 28p sitting in the cuddly. had it out yesterday for the first time. It appears this is not propped correctly. Full tank of fuel and 4 adults on board.. Seems sluggish getting on plane. Once on plane and trimmed up it cruises pretty well. But at wot it will over rev. I was seeing 56-57 mph on gps at like 5200-5300 and I would get an alarm. I should be at around 5000 max correct? Why would someone want a prop like this. I would expect it to under rev with a prop this aggressive. Any help would be great. I believe I should be mid 60’s with a little lighter load than I had thanks in advance.
Running your numbers in calculator with 1.65 drive I get 31% slip. Guess that is possible with real bad prop. What is the prop?( brand, diameter, blades)
Not being degrading in any way it are you trimmed out correctly?
WOT and bump drive up very slowly?
Prop is a bravo ss 28p. don’t know diameter and don’t know if it has been messed with. No damage on prop. My winterizing guy said it had definitely been messed with. There is a cup at the end. Boat is out being winterized so I can’t give diameter. I will once I have the boat back. As far as trim I am trimmed up nearly all the way. Like trim gauge is reading between 1/2 and 3/4 up.
