Camshaft Recommendations >
Old 10-16-2024 | 02:49 PM
Default Camshaft Recommendations
Who is the best person or company for custom or semi/custom cams?
jeffswav is offline
Old 10-16-2024 | 03:05 PM
F-2 Speedy's Avatar
This should be a good as an oil thread..........you really need to take in all of the components of the build to spec a cam, in a lot of cases the proven Mercury grinds will work well.
F-2 Speedy is offline
Old 10-16-2024 | 03:27 PM
[QUOTE=F-2 Speedy;4911696]This should be a good as an oil thread..........you really need to take in all of the components of the build to spec a cam, in a lot of cases the proven Mercury grinds will work well.[/QUOT]
Exactly, great way to start off. Not actually looking for advice on cam specs. I know pretty much what I want, been through this before. A lot has changed in the business. I was going to pull up one of my old threads but started fresh this time. If you want to give your 2 cents I will post my specs and what I am looking for.
jeffswav is offline
Old 10-16-2024 | 04:04 PM
F-2 Speedy's Avatar
Bullet cams is talked about here, personally Ive not used them, Lunati , TCM in Cali has some off the shelf cams but I dont think they grind them. I had cam motion do a custom grind for some 540's but that was 9 years a go
Old 10-16-2024 | 06:46 PM
i have found bullet by far to be the best to work with they have made a few custom ones for us and they rock, even a reverse rotation big chief supercharged cam
boostbros is offline
Old 10-16-2024 | 07:58 PM
bullet cams for me to,,,they got me stepped nose gen 6 double swap high lift cam cores for a custom grind.
sutphen 30 is offline
Old 10-16-2024 | 09:14 PM
Comp Cams and Billy Golds is my go to .
ICDEDPPL is offline
Old 10-18-2024 | 06:14 PM
Rookie's Avatar
Comp Cams. They spintron all of their lobes for stability.
Also, never heard a bad word about a Bullet camshaft. I use to run Ultradyne cams before they were bought by Bullet. Now I buy Comp.
Rookie is offline
Old 10-19-2024 | 02:33 PM
I've had great experiences with Howard cams. A bit more expensive than a lot of other off the shelf ones but haven't had a bad product
CheckmateScarab is offline
Old 10-20-2024 | 11:44 AM
Chris Straub in East Tennessee is highly regarded by a lot of builders. I'll be getting my next one from him to try out.
Smitty275 is offline
